MacBook Air Models A1237 and A1304 Display Assembly Replacement
Выберете то, что вам нужно
Видео обзор
  1. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 2, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 2, изображение 2 из 2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Battery: шаг 3, изображение 1 из 1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 4, изображение 1 из 1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 5, изображение 1 из 1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Hard Drive: шаг 6, изображение 1 из 3 MacBook Air Models A1237 and A1304 Display Assembly Replacement, Hard Drive: шаг 6, изображение 2 из 3 MacBook Air Models A1237 and A1304 Display Assembly Replacement, Hard Drive: шаг 6, изображение 3 из 3
    • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
    • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
    • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
    I skipped the step (6c) of prying the audio out ribbon cable connector board off the hard drive bracket (& disconnecting it), since it doesn't come off real easily, and I didn't want to damage it. It only requires a little more care when removing the HD from it's bracket if you skip step 6c.
    amiller770 - Ответить
  7. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 7, изображение 1 из 1
    • Disconnect the audio out cable from its socket on the port hatch ribbon cable.
    This is not necessary and looks pretty risky too.
    eugene_o - Ответить
    Agreed, I encountered no issues when I skipped this on a Rev.B model.
    Kyle Milnes -
  8. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 8, изображение 1 из 1
    • Use a spudger to pry the hard drive cable connector up off the logic board.
    Reversing step 8 is where I ran into trouble. The replacement fan I had was slightly thicker than the original and caused the ZIF cable to work its way out of the tenuous connection it had to the SSD, resulting in a "?" missing boot drive error upon startup. Took me three tries to get it right! The difficulty is to get the drive connector to the logic board to reach and seat without pulling the other end out of the drive.
    aaronmiller - Ответить
  9. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 9, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 9, изображение 2 из 2
    • Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
    • Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
  10. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 10, изображение 1 из 1
    • Remove the four Phillips screws securing the hard drive assembly to the upper case:
    • Two 4.7 mm screws.
    • Two 3.9 mm screws.
    Two 3.9 mm Phillips screws.
    Two 4.7 mm Phillips screws.
    Alvaro Hermida - Ответить
    There is a cable glued to the diskframe that must be loosened with a spudger before you can remove the frame.
    oysteinalsaker - Ответить
  11. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 11, изображение 1 из 1
    • Lift the hard drive assembly out of the upper case.
    Ever since Steve Jobs died, Apple hasn't been what it used to be.
    George A. - Ответить
  12. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Heat Sink: шаг 12, изображение 1 из 1
    • Use the tip of a spudger to pull the fan cable connector straight away from its connector on the logic board.
  13. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 13, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 13, изображение 2 из 2
    • Use the tip of a spudger to move the cosmetic fan cover aside.
  14. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 14, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 14, изображение 2 из 2
    • If you have the original version of the MacBook Air (A1237), refer to picture 1. Remove the following screws securing the heat sink to the logic board:
    • One 5.9 mm Phillips screw.
    • Two 1.9 mm Phillips screws.
    • One 1.9 mm Phillips screw.
    • If you have the A1304 version of MacBook Air, refer to picture 2. Remove the following screws securing the heat sink to the logic board:
    • One 5.0 mm Phillips screw
    • Five 1.9 mm Philips screws.
    • One 2.5 mm Phillips screw.
    On A1237, the yellow screw is a bit longer then the two orange ones.
    Peterdk - Ответить
    I have replaced several Logic boards at this point on the A1304 model, and realized that I did not need to remove the heatsink (Steps 14 through 17). You need to remove the screws around the fan, and disconnect the microphone cable (step 19). Of course if your replacement logic board doesn't include a heatsink, you need to take it off.
    Steerpike - Ответить
  15. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 15, изображение 1 из 1
    • Lift the processor clamp off the heat sink.
  16. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 16, изображение 1 из 1
    • Deroute the microphone cable away from the channel in the fan.
  17. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 17, изображение 1 из 1
    • Lift the heat sink up off the logic board.
    • Be mindful of the microphone cable when lifting the heat sink, as it can get tangled on the top edge of the fan.
    • When you mount the heat sink back onto the logic board, be sure to apply a new layer of thermal paste. We have a guide that makes replacing the thermal paste easy.
    I removed the fan at this point as well. Disconnect the small connector from the fan to the logic board and lift out the fan. Good time to blow off the dust!
    Andrea Wang - Ответить
  18. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Logic Board: шаг 18, изображение 1 из 1
    • Use a spudger to pry the audio cable connector up off the logic board.
  19. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 19, изображение 1 из 1
    • If present, remove the small piece of black tape covering the microphone cable connector.
    • Disconnect the microphone cable by pulling its connector straight away from the socket on the logic board.
  20. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 20, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 20, изображение 2 из 2
    • Remove the two small Phillips screws securing the logic board bracket to the upper case.
    • Lift the logic board bracket out of the upper case.
  21. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 21, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 21, изображение 2 из 2
    • Use a spudger to pry the AirPort/Bluetooth and trackpad control cable connectors up off the logic board.
  22. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 22, изображение 1 из 1
    • Disconnect the DC-In cable by pulling its connector straight away from the socket on the logic board.
  23. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 23, изображение 1 из 2 MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 23, изображение 2 из 2
    • Remove the small Phillips screw securing the display data cable ground loop to the upper case.
    • Disconnect the display data cable by pulling its connector straight away from the socket on the logic board.
  24. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 24, изображение 1 из 1
    • Remove the three Phillips screws securing the logic board to the upper case.
  25. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 25, изображение 1 из 1
    • Lift the logic board out of the upper case.
  26. MacBook Air Models A1237 and A1304 Display Assembly Replacement, Display Assembly: шаг 26, изображение 1 из 1
    • Remove the two following screws securing the AirPort/Bluetooth board bracket to the upper case:
    • One 4.7 mm Phillips.
    • One 3.9 mm Phillips.
    The plastic Airport/Bluetooth bracket provides additional resistance and the 3.9 mm screw is easily stripped. Remove carefully.
    Robert Calhoun - Ответить
  27. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 27, изображение 1 из 1
    • Lift the AirPort/Bluetooth bracket out of the upper case.
  28. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 28, изображение 1 из 1
    • Use a spudger to pry the three antenna cables up off the AirPort/Bluetooth board.
    Note: If you are not replacing this card, you don't have to disconnect the bottom two cables. You will need to remove the top cable to access the screw. Use care.
    rmohns - Ответить
  29. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 29, изображение 1 из 1
    • Peel the antenna cables up off the adhesive securing them to the upper case.
  30. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 30, изображение 1 из 1
    • Remove the single Phillips screw securing the microphone cable ground loop to the upper case.
  31. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 31, изображение 1 из 1
    • Remove the following 15 screws:
    • Thirteen 2.3 mm Phillips.
    • Two T6 Torx.
    • Leave one T6 Torx screw in each side of the display bracket.
  32. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 32, изображение 1 из 1
    • Open the Air so the display is perpendicular to the upper case and place it on a table as shown.
    • While holding the top of the Air with one hand, remove the T6 Torx screw from the lower display bracket.
  33. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 33, изображение 1 из 1
    • Be sure to hold the Air together while you remove the last Torx screw. Failure to do so may cause the display/upper case to fall, potentially damaging both components.
    • Remove the T6 Torx screw from the upper display bracket.
  34. MacBook Air Models A1237 and A1304 Display Assembly Replacement: шаг 34, изображение 1 из 1
    • Pull the upper case straight away from the display, minding any cables that may get caught.
Заключение
116 участников успешно повторили данное руководство.
7 Комментариев
Great guide. I was able to remove the components without any trouble. Be sure to label your screws, as there are so many.
Steven Hanlon - Ответить
Do you have a guide to put that macbook back togerher?
Antonio Korts -
I was able to replace broken hinges without replacing the whole display. It takes patience and a bit of courage but it's doable (except if you are blonde and cute I guess ;)
Alfredo Sola - Ответить
Buenas tardes Alberto. Tengo necesidad de sustituir una bisagra de este modelo y no sé donde puedo adquirirla. Le agradecería que me dijera donde puedo comprarla. muchas gracias por adelantado
jose enrique guijarro martinez -
Thanks for the guide. My internal microphone stopped working but unfortunately I was not able to fix it. Still, very helpful guide.
pentzini - Ответить
Are you able to replace the display and hinges only? My Wi-Fi antenna is still in tact.
Dawsyn Arnold - Ответить
Hi! I have problem. I bought screen from MacBook Air A1304 (2009), but I have broken MacBook Air model A1466 (2014). Will it fit?
Helena Gajda - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 25
За последние 30 дней: 94
За всё время: 182,053
