Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95-
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
The lower case is connected to the upper case at the center, with two plastic clips.
Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
Инструмент, используемый на этом этапе:Tweezers$4.99-
Remove any broken or damaged feet.
If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
Align the new foot inside the cavity.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
Repeat the last seven steps for any remaining broken or worn feet.
8 участников успешно повторили данное руководство.
Один комментарий
Great kit for replacing the feet on a MacBook. Had a foot fall off my 6 year old MacBook Pro and this kit fit exactly!
