Введение
Have your MacBook Pro feet seen better days? Use this guide to give your Mid 2015 MacBook Pro a fresh set of feet.
Выберете то, что вам нужно
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove any broken or damaged feet.
If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
Align the new foot inside the cavity.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
Repeat the last seven steps for any remaining broken or worn feet.
25 человек успешно провели ремонт по этому руководству.
