Введение
Use this guide to upgrade or replace the solid-state drive in a MacBook Pro 15” Mid 2015. This MacBook Pro uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Finally, we strongly recommend installing macOS 10.14 Mojave (or a later macOS) before replacing the original SSD from your MacBook Pro. Most new SSDs require updated storage drivers not found in versions of macOS prior to macOS 10.14 Mojave.
Запчасти
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Lift the end of the SSD up enough to pass over the speaker directly behind it.
Pull the SSD straight out of its socket on the logic board.
257 участников успешно повторили данное руководство.
Комментариев: 76
So guys, I got a couple of questions:
1. Is this model (MBP Retina Mid 2015/MacBookPro11,4 ) really upgradable? https://www.datenreise.de/en/macbook-pro... says otherwise.
2. Samsung 850 EVO or Samsung 850 PRO would work with the model mentioned above?
Yes, it is upgradeable. At the time that article was published there was no drive on the market that would work. Now there is. No the Samsung 850 EVO or Pro would not work. As far as I know OWC is the only one that produces an after market drive that is compatible.
I couldn't find the SSD that Chris mentioned. Would you please point out the exact model?
It’s the OWC Aura Pro X2, you can get it all the up to 2TB.
