MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement
Выберете то, что вам нужно
  1. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 2, изображение 1 из 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement, Battery: шаг 3, изображение 1 из 1
    • Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
    • Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
  4. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 4, изображение 1 из 1
    • Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-point screw.
    • Remove the last 7.4 mm Tri-point screw securing the battery to the upper case.
  5. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 5, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 5, изображение 2 из 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 6, изображение 1 из 1
    • Tilt the battery away from the logic board enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • Pull the battery cable connector away from the center of the logic board.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  7. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement, Display: шаг 7, изображение 1 из 1
    • Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
  8. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 8, изображение 1 из 1
    • Pull the camera cable connector straight out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the optical drive opening.
  9. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 9, изображение 1 из 1
    • Use the tip of a spudger to pry the three antenna connectors up off the AirPort/Bluetooth board.
  10. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 10, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 10, изображение 2 из 2
    • De-route all three antenna cables from their channels in the AirPort/Bluetooth housing.
    • De-route the camera cable from its channel in the AirPort/Bluetooth housing.
  11. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 11, изображение 1 из 1
    • Remove the following two screws securing the AirPort/Bluetooth housing to the upper case:
    • One 3.8 mm Phillips
    • One 8.6 mm Phillips
  12. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 12, изображение 1 из 1
    • Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
  13. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 13, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 13, изображение 2 из 2
    • Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
    • Remove the antenna/camera cable retainer from the upper case.
  14. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 14, изображение 1 из 1
    • Remove two of the three 6 mm T6 Torx screws securing the right side of the display to the upper case.
    • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
  15. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 15, изображение 1 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 15, изображение 2 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 15, изображение 3 из 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  16. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 16, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 16, изображение 2 из 2
    • Remove the 8.6 mm Phillips screw securing the display data cable retainer to the upper case.
    • Remove the display data cable retainer from the upper case.
  17. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 17, изображение 1 из 1
    • Remove two of the three 6 mm T6 Torx screws securing the left side of the display to the upper case.
  18. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 18, изображение 1 из 1
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the upper display bracket.
  19. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 19, изображение 1 из 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T6 Torx screw securing the display to the upper case.
  20. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 20, изображение 1 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 20, изображение 2 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 20, изображение 3 из 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
  21. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement, Front Bezel: шаг 21, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement, Front Bezel: шаг 21, изображение 2 из 2
    • It's very easy for the rubber display gasket to deform when exposed to heat, so it is best to remove it before using a heat gun to remove the display glass.
    • Insert the tip of a spudger underneath the black rubber gasket at the bottom right corner of the display assembly.
    • Gently pry the wide edge of the gasket up from the back case.
  22. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 22, изображение 1 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 22, изображение 2 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 22, изображение 3 из 3
    • Starting with the freed corner, pull the rubber gasket off the right side of the display assembly.
  23. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 23, изображение 1 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 23, изображение 2 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 23, изображение 3 из 3
    • Continue pulling the display gasket off the display assembly across the top edge.
  24. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 24, изображение 1 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 24, изображение 2 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 24, изображение 3 из 3
    • Continue pulling the display gasket off the display assembly down the left side.
    • Pull the gasket off the bottom edge of the display to completely free it and set it aside.
  25. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 25, изображение 1 из 1
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer silver border around the underside of the front panel to the display.
    • With the heat gun set to low, start by heating the metal bezel surrounding the LCD.
    • When using the heat gun, the goal is to soften a layer of adhesive holding the bezel to the display assembly. Be very careful not to overheat the LCD, as it could cause permanent damage.
  26. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 26, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 26, изображение 2 из 2
    • Carefully insert a guitar pick between the top right corner of the bezel and the display assembly.
    • Use the guitar pick to gently pry up the adhesive along the top edge securing the bezel to the display assembly.
    • The bezel is very thin metal, so be very careful not to crease it as you pry it up.
  27. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 27, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 27, изображение 2 из 2
    • If necessary, use a heat gun to reapply heat along the top right edge to loosen the adhesive securing the bezel to the display assembly.
    • Work along the top right edge of the display assembly, carefully prying the adhesive up with the guitar pick. Stop when you get to the iSight camera.
    • Do not pry near the iSight camera—there is no adhesive immediately surrounding it, and you could damage the camera with the guitar pick.
  28. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 28, изображение 1 из 1
    • Use a heat gun to soften the adhesive under the bezel along the left and top left edges of the display.
  29. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 29, изображение 1 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 29, изображение 2 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 29, изображение 3 из 3
    • Carefully insert a guitar pick between the top left corner of the bezel and the display assembly.
    • Use the guitar pick to gently pry up the adhesive along the left edge securing the bezel to the display assembly.
  30. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 30, изображение 1 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 30, изображение 2 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 30, изображение 3 из 3
    • Repeat the procedures in the two previous steps for the right edge of the display.
  31. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 31, изображение 1 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 31, изображение 2 из 3 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 31, изображение 3 из 3
    • Work along the top left edge of the display assembly, carefully prying the adhesive up with the guitar pick. Stop when you get to the iSight camera.
  32. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 32, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 32, изображение 2 из 2
    • Wedge a guitar pick in between the bezel and display assembly near the inner bottom left corner.
    • Work along the inner bottom left edge of the display assembly, carefully prying the adhesive up with the guitar pick.
    • Continue prying along the inner bottom edge to release the adhesive securing the bezel to the display assembly.
  33. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 33, изображение 1 из 1
    • Use a guitar pick to gently lift the bottom right corner of the bezel.
  34. MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 34, изображение 1 из 2 MacBook Pro 15" Unibody Mid 2010 Front Bezel Replacement: шаг 34, изображение 2 из 2
    • Slowly lift the bottom edge of the bezel and gently rotate it out of the display.
Заключение
4 человек успешно провели ремонт по этому руководству.
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 49
За всё время: 10,892
