MacBook Unibody Model A1278 Front Display Glass Replacement
Выберете то, что вам нужно
  1. MacBook Unibody Model A1278 Front Display Glass Replacement, Access Door: шаг 1, изображение 1 из 1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
    This is not a a1278 unibody MacBook Pro. A1278 MacBooks backs are one solid metal piece not two separate pieces. This guide is for a different MacBook Pro.
    Brad Burgeson - Ответить
    This guide isn’t for a pro; it’s a MacBook unibody.
    Nicholas -
    So, it turns out that Apple used the model code A1278 for quite a few different Mac models, including both Pro and non-Pro versions! This guide is for the non-Pro Macbooks. There’s also one for the Pro models with the same A1278 identifier.
    tempelmann - Ответить
  2. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 2, изображение 1 из 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 Front Display Glass Replacement, Battery: шаг 3, изображение 1 из 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
    Great tutorial ! great step !
    Leo Etcheverry - Ответить
    Even though it’s specifically stated, you have to make sure the access door latch is vertical or the battery won’t be removable.
    Henry Kim - Ответить
  4. MacBook Unibody Model A1278 Front Display Glass Replacement, Lower Case: шаг 4, изображение 1 из 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
    On my model, it seemed the top-left was 3.5mm and the bottom 4 were 3 mm.
    Jim - Ответить
    Make sure you have a good quality Phillips screwdriver. Mine had removable tips and had a small play at the connection. As a result I didn't have a good feel and damaged my screws (those securing the fan and the top left in step 23). Game over for me installing new thermal paste...
    Be very carefull with your screws! Especially those on the inside.
    Nickolas Michelinakis - Ответить
    You can get away with a Phillips #00 for many of the screws involved but the 4 at the bottom case split are likely to strip if you don’t use a JIS #00 or, in a pinch, a Phillips #000.
    Bill Cole - Ответить
    I used the Phillips #00 tip from my Pro Tech Toolkit, and it worked well enough. But yes, maybe #000 might have been better on the lower row of screws. Note to myself: Always read the comments first.
    Les Kitchen -
    When replacing these screws, the order to replace them in is as follows:
    1, Top left
    2. Top right
    3. Top center-left
    4. Top center-right
    5. Bottom center-right
    6. Bottom center-left
    7. Bottom right
    8. Bottom left
    I hope this information is helpful.
    facebook - Ответить
    I followed my usual process of putting in all the screws loosely, then tightening them gradually in distributed pattern, to help ensure that the panel settles in place evenly. But maybe some orders are better.
    Les Kitchen -
  5. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 5, изображение 1 из 1
    • Using both hands, lift and remove the lower case off the upper case.
    Thanks for the guide!
    It's implicit in the two photos, but worth mentioning because it blocked my progress in this step for a bit: You have to put the release latch back into its horizontal, closed position before you can lift off the lower-case panel.
    Les Kitchen - Ответить
  6. MacBook Unibody Model A1278 Front Display Glass Replacement, Display Assembly: шаг 6, изображение 1 из 1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Be careful not to pull up on the cable as you remove it from the socket.
    Be EXTREMELY careful when removing and re-inserting the 'camera' cable. The contacts can be easily bent beyond repair if you try to force it back in. Damaging this cable at this connection or near the display may disable your ability to use your iSight camera, AND both your Bluetooth and WiFi. I had to pay apple $300 to replace the entire display assembly because one prong was faulty, causing my WiFi card to not be recognized.
    seanheff17 - Ответить
  7. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 7, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 7, изображение 2 из 2
    • De-route the camera data cable from the channel in the optical drive.
    Although I ordered the screen for an A1278 MacBook Unibody Aluminum, the screen glass was marked as a MacBook Pro. The iSight/WiFi /BT cable was about an inch longer than the Macbook one and took a bit of creative re-routing, but everything works fine.
    tjod - Ответить
    has it got the airport and bluetooth modules built in separately in the display assembly as in the macbook late 2008 and mbp mid 2009?
    fericcio -
  8. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 8, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 8, изображение 2 из 2
    • Remove the following screws securing the camera data cable and right speaker to the upper case:
    • One 9.9 mm partially threaded Phillips screw
    • One 9.6 mm threaded Phillips screw
    • One 4 mm Phillips screw
    • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
    • The iSight cable has an eyelet through which passes the left-most screw in these pictures.
    "orange" is the short one, that goes in the middle ;)
    Riesling - Ответить
    My model has different bracket, you need to remove the subwoofer first
    Andrea Ghensi - Ответить
    1. With my Laptop, the left screw was partially threaded, not the right one. 2. Before removing the camera cable bracket, I needed to unscrew the subwoofer.
    Edgar Fuß - Ответить
  9. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 9, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 9, изображение 2 из 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector straight away and not straight up from its socket.
    i can't understand what I need to do in this step, I'm afraid with this step, i think i can "hurt" my mac and i don't want to do that, anyone knows what i need to do?
    Thanks
    Lucas Borges - Ответить
    There is a steel 'latch' that flips over from the left side of the connector, to the right side. After you flip this latch over, the cable will easily slide out.
    madmaxmedia - Ответить
    as I pulled the monitor cable out of the bracket after flipping the lock over one side of the bracket broke loose. Now the monitor will not turn on. Can anyone help?
    boldtu - Ответить
  10. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 10, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 10, изображение 2 из 2
    • Remove the following two screws from the display data cable bracket:
    • One 7 mm Phillips screw.
    • One 5 mm Phillips screw.
    • Lift the display data cable bracket out of the upper case.
    Note for Step 10 during reassembly: Be careful when replacing the screw for the display cable bracket closest to the magnetic power cord receptacle. The interior magnet might attract the screw causing the screw to get pulled under the DC power circuit board which might then require that you disassemble things again to retrieve the screw.
    wintermute - Ответить
  11. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 11, изображение 1 из 1
    • Remove the two outer 6 mm Torx screws securing each side of the display to the upper case (4 screws total).
    Hey guys, with these older models Do Not interchange different colored LVDS cables. Note the connector here is gold, do not use a silver connector on a gold one or vice versa. I fried a logic board this way on an A1278. Note that the core i7 lvds connector is different than the core i5.
    rjpoirier_nb - Ответить
    I never thought that I’d be required to use PB Blaster to remove computer screws. Had to use two tiny drops for each screw, letting it soak in for 20 minutes or so. The display screws, coated with blue thread lock, did not want to budge. I was so fearful that I would strip them using a T-6 driver. Ended up using a 1/4” drive ratchet with a T-6 bit, pressing down firmly and blocking the MacBook from turning with my elbows. I’ve had a lot of experience doing this kind of work, but wow!
    randy3833 - Ответить
  12. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 12, изображение 1 из 1
    • Open your MacBook so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the 6 mm Torx screw from the lower display bracket.
  13. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 13, изображение 1 из 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm Torx screw securing the display to the upper case.
  14. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 14, изображение 1 из 3 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 14, изображение 2 из 3 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 14, изображение 3 из 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display away from the upper case, minding any brackets or cables that may get caught.
  15. MacBook Unibody Model A1278 Front Display Glass Replacement, Front Display Glass: шаг 15, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement, Front Display Glass: шаг 15, изображение 2 из 2
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
  16. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 16, изображение 1 из 3 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 16, изображение 2 из 3 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 16, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Купить
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
    I'm having trouble getting the display glass off. I was able to put a card into a gap, but it wasn't the display case, but the entire lcd panel. Any ideas?
    Taylor Vanderwarker - Ответить
    My display glass had multiple, long cracks, which is why I set out to replace it.
    Lifting the screen didn't work as the suction cup was always over a crack and didn't take. I ended up lifting a piece of screen from the middle, existing cracks making it easy, and then had to go around the edge with a metal scrape to lift and remove the glued edge of the glass.
    Took about two hours but it worked. Small splinters flying everywhere (goggles!). Made three inspection passes with a magnifying glass to clean up every little shard of glass and leftover glue. Everything else went fine!
    sergio.duroux - Ответить
    If you have cracks on the screen, use packing tape on the screen to get better grip with suction cup.
    Jesse Nayak -
    Really need to amend this step... I think it is easier to break the double sided stick by SLOWLY rocking it side to side motion w/ the suction cup (macbok logo to camera) from either side of the Macbook logo.
    Steve Yeung - Ответить
    I overheated rubber strip and it is permanently deformed, as you said. Where can I find it ? Do you have it ? hanks a lot, regards
    Juanpablo - Ответить
  17. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 17, изображение 1 из 3 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 17, изображение 2 из 3 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 17, изображение 3 из 3
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  18. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 18, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 18, изображение 2 из 2
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
  19. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 19, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 19, изображение 2 из 2
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
  20. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 20, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 20, изображение 2 из 2
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
  21. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 21, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 21, изображение 2 из 2
    • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
  22. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 22, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 22, изображение 2 из 2
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on. It is recommended to use a silicon roller and sticky sheets to clean well.
  23. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 23, изображение 1 из 2 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 23, изображение 2 из 2
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
  24. MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 24, изображение 1 из 3 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 24, изображение 2 из 3 MacBook Unibody Model A1278 Front Display Glass Replacement: шаг 24, изображение 3 из 3
    • During the glass removal process, the AirPort & iSight data cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your AirPort & iSight data cable is still connected to the camera board, skip this step.
    • If your objective is to remove the camera board, skip this step as reconnecting the AirPort & iSight data cable is not necessary.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the AirPort & iSight data cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the AirPort & iSight data cable socket.
    • Insert the AirPort & iSight data cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the AirPort & iSight data cable socket.
    I used this guide to successfully replace the glass on a 2012 unibody 13” Macbook Pro.
    If you are replacing the glass due to cracking/breaking, you’ll want to cover the entire surface with clear packing tape to keep shards from going everywhere. You can’t use the suction cups, since the glass will continue to crack as you pull on it, breaking the suction. I used an iSesamo and heat gun to pry the edge up, and then scrape off remaining shards around the edges.
    Mark - Ответить
Заключение
48 участников успешно повторили данное руководство.
16 Комментариев
oh! and great organization tip for the screws: i poked them thru a piece of notebook paper with the corresponding steps written next to them. it worked like a charm, far better than anything else i could think of.
well, i didn't have the required suction cup... and so after trying for about 5 minutes with the iphone suction cups, i just picked at the broken glass (most of us have the broken screens, right?) and it went much better. i was worried about scratching the LCD as i picked and scraped, so be gentle, and wary of that. it was a fun/nerve-wracking 3.5 hours.
brianisbrillian - Ответить
Agree, forget about getting the glass off in one try. Apparently the glue hardens out a bit, I couldn't get the screen off with the ordered suction cups. In the end I did the same as Brian above: just kept breaking off more glass until the LCD was free, then painstakingly removed the bits around the border with a sharp knife. Just be careful.
Keep a vacuum cleaner nearby, as you'll end up with lots of microscopic glass fragments.
I vacuumed the LCD then sprayed LCD cleaner on & wiped it with a microfiber cloth. This worked very well. Make sure you get all the glass fragments off the border as well, I missed one and now the border makes a bit of noise if you press down there.
kees - Ответить
Everything on this review seemed to work rather flawlessly for me up until the point where I had to use the heat gun and suckers to remove the cracked screen. After much use of the heat gun (hairdryer in my case) I feared that the LCD may be effected by the excessive heat, so I started to carefully breaking away at my already cracked screen. With the screen not trapped beneath a sheet of glass and able to breathe, I felt much more relaxed about using the hairdryer to loosen glue around the edges. After a short amount of picking, and scraping, I managed to get all the glass shards off and apply the new glass screen. It was helpful to have another set of hands to position the hairdryer as I moved along to enable faster separation of glass from the panel. Good as new after mind you! Don't let the 9/10 difficulty rating deter you, just be careful, organized and take your time :)
Darragh Flynn - Ответить
I totally agree: if your glass is broken (a good reason why you may be looking how to change it) you'll have to be VERY patient. It is very likely that the glass will break in hundreds of tiny pieces while performing these operations. My experience says: 1) Heat the adhesive thoroughly to minimize the work. 2) Go fetch some glasses to protect your eyes. 3) Good Luck! :)
fbeeper - Ответить
BTW, if your model is a 13" Late 2008 MacBook you can go for the 13" MacBook Pro 2009+ glass. It fits, and you're old Mac will get a fun cosmetic upgrade :P
fbeeper - Ответить
Excellent guide. Thank you. I covered my whole screen with 2" clear packing tape (over the see-through parts only). I used a bit less heat that I probably could have, and I ended up carefully prying off small glass shards, one by one, over the adhesive areas. Once the sides and top were done, I was able to heat the bottom, and remove the entire glass in one piece by hinging it down to un-stick the bottom. This helped keep the LCD perfectly clean during the removal process. Once the old glass was completely removed, I used pieces of scotch tape to remove any dust particles that landed on the LCD while it was bare. Then I immediately installed the new glass. Before my screen was cracked all over and it looked horrible. Now it looks as good as new. You can't tell it was repaired!
P H - Ответить
Why is it necessary to remove the display from the laptop before removing the glass? I've gone over the steps and can't understand why. Thank you! Charles
Charles - Ответить
like @Charles, I'd also like to know why it is necessary to remove the display from the laptop - from come comments on other forums I have heard people say it can be done with the display still attached, which would seem much easier.
Mick O'Doherty - Ответить
Hello, what kind of glue should I use to fix the new new glass on?
kekko690 - Ответить
Don’t use glue. Use double-coated tissue tape, also known as adhesive transfer tape, which applies like a double-sided adhesive tape, but after you peel away the outer covering layer all that is left is a thin adhesive layer. Easy to cut to length and shape to precisely apply to the frame for the glass will adhere to. The adhesive should be a low surface energy acrylic adhesive, such as 3M 300LSE:
https://www.3m.com/3M/en_US/company-us/a...
Another that I’ve used several times is 3M 9448A but the description says “formulated to hold well even in high temperatures”, which might make it harder to replace the glass again:
irvbromberg - Ответить
The suction cup won’t be able to attach well if glass is cracked beneath it. Use clear packing tape to cover the crack(s) — this helps the suction cup hold well and helps prevent further breakage of the glass.
It’s hard to control where a heat gun blows. An alternative that is easier to control and confine to the target area is a microwave heated heat-retaining bag, such as the iFixit iOpener. Similar microwave heating bags are sold by drugstores.
Why disconnect the display assembly? Well, you really need the display assembly to lie flat on a table while you work on it. With this model MacBook when the display is opened all the way and laid flat on a table the laptop’s body will be at about a 45 degree angle relative to the table, and would be a challenge to securely support while you work on the display. If you do have a good way to support the laptop then it’s still important to remove the battery to prevent it from accidentally getting powered on.
It looks like my several comments are more than 3 years too late for those who commented previously. Oh well…
Absolute Glazing is Central Coast’s leading glaziers providing the very best glass service solutions for your residential and commercial needs. Whether it’s a new glass installation or an emergency glass replacement, we’ve got you covered 24 hours a day, 7 days a week.
<a href="https://absoluteglaziers.com.au/">Glaziers Central Coast</a>
mie dojaylo - Ответить
Disculpa Una pregunta la Memoria RAM 8GB 2x4GB Corsair CMSA8GX3M2A1333C9 Mac Memory son compatibles con la MacBook de finales de 2008, con procesador Intel Core 2 Duo a 2Ghz es que ando buscando estás que si son compatibles memoria de Corsair para Mac, un kit de dos memorias CMSA8GX3 de 4gb y no las encuentro
Sergio Rojas - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 27
За всё время: 73,701
