MacBook Unibody Model A1278 Hard Drive Replacement
Выберете то, что вам нужно
  1. MacBook Unibody Model A1278 Hard Drive Replacement, Access Door: шаг 1, изображение 1 из 1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 Hard Drive Replacement, Battery: шаг 3, изображение 1 из 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. MacBook Unibody Model A1278 Hard Drive Replacement, Hard Drive: шаг 4, изображение 1 из 1
    • Remove the single Phillips screw securing the hard drive bracket to the upper case.
    • This screw is captive to the hard drive bracket.
  5. MacBook Unibody Model A1278 Hard Drive Replacement: шаг 5, изображение 1 из 1
    • Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
    • Lift the hard drive out of the chassis, minding the cable attaching it to the computer.
  6. MacBook Unibody Model A1278 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
    • Hard drive remains.
  7. MacBook Unibody Model A1278 Hard Drive Replacement, Hard Drive: шаг 7, изображение 1 из 1
    • Remove the two T6 Torx screws from each side of the hard drive (four screws total).
    • You'll need to transfer these screws to your new hard drive if you're changing drives.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Заключение
430 человек успешно провели ремонт по этому руководству.
8 Комментариев
Radio shack has a small kit with assorted bits that includes all of the t bits
Ryan - Ответить
just to be save a quick .. use super duper first on your new hdd to clone the old one... (if possible) and after installing... its like you have the same drive... no loss of files.... easy does it!
Britt - Ответить
Very easy and worth the upgrade
Ivan Juarez - Ответить
The model A1278 in front of me doesn't look like the above. It has 10 screws holding a single piece base onto the body, and not a single quick-release catch in sight. The battery bay looks different as well, but removing the HDD is just as easy.
StripyDonkey - Ответить
That is because you are looking at a MacBook Pro A1278, not the MacBook Unibody. Apple made the regular MacBook in an aluminum enclosure in 2008 and the following aluminum model was changed to be called the MacBook Pro.
Frank Malinowski -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 16
За последние 7 дней: 82
За последние 30 дней: 310
За всё время: 327,858
