How to Install macOS High Sierra
Выберете то, что вам нужно
    1. How to Install macOS High Sierra, How to Install macOS High Sierra: шаг 1, изображение 1 из 2 How to Install macOS High Sierra, How to Install macOS High Sierra: шаг 1, изображение 2 из 2
      • With the device powered off, disconnect any external hard drives and flash drives.
      • Plug in your macOS High Sierra bootable flash drive.
      • Hold down the [option] or [alt] (⌥) key on the keyboard and power on the device.
      • When you see the boot selection screen as shown, release the [option] key.
      • Use either the keyboard's arrow keys or the mouse to select "Install MacOS High Sierra." Press [enter] or click your selection with the mouse.
      Спросите у FixBot
      Добавить комментарий
    2. How to Install macOS High Sierra: шаг 2, изображение 1 из 2 How to Install macOS High Sierra: шаг 2, изображение 2 из 2
      • Your Mac will begin copying the installation files from the flash drive. This may take up to 30 minutes.
      • Depending on the speed of your flash drive, it may look like progress has frozen, but it should resume if you continue to wait.
      • When prompted, select your language and press [enter], or click the arrow button.
      Спросите у FixBot
    3. How to Install macOS High Sierra: шаг 3, изображение 1 из 2 How to Install macOS High Sierra: шаг 3, изображение 2 из 2
      • If you don't need to pre-configure your hard drive, skip to step 5. If you're not sure or if the drive is used, it's a good idea to pre-configure your hard drive.
      • Select "Disk Utility" from the menu and press [enter] or click the continue button.
      Спросите у FixBot
    4. How to Install macOS High Sierra: шаг 4, изображение 1 из 3 How to Install macOS High Sierra: шаг 4, изображение 2 из 3 How to Install macOS High Sierra: шаг 4, изображение 3 из 3
      • Select your hard drive from the left column in Disk Utility.
      • It is most likely the uninitialized drive.
      • If you have multiple hard drives, make sure you select the correct one as the next step will wipe the selected drive clean.
      • Click the "Erase" button at the top of the window.
      • Choose a name for your drive (you can rename it later). Leave the scheme as GUID Partition Map.
      • If you are installing an SSD, choose the APFS format. If you are installing a mechanical drive or if your device doesn't officially support the newer OS, leave the format as Mac OS Extended (journaled)
      • Click "Erase." When the process completes, click "Done."
      • Exit the Disk Utility by clicking on the red X button on the top left corner of the window.
      Спросите у FixBot
    5. How to Install macOS High Sierra: шаг 5, изображение 1 из 2 How to Install macOS High Sierra: шаг 5, изображение 2 из 2
      • Select "Reinstall macOS" from the menu and press [enter] or click "Continue."
      Спросите у FixBot
    6. How to Install macOS High Sierra: шаг 6, изображение 1 из 3 How to Install macOS High Sierra: шаг 6, изображение 2 из 3 How to Install macOS High Sierra: шаг 6, изображение 3 из 3
      • Read through the license agreement.
      • Click "Agree" to accept the license agreement.
      • Your Mac will now install macOS High Sierra. Be patient and wait for it to complete.
      • Once the install is complete, the device will restart itself.
      Спросите у FixBot
Заключение
High Sierra should now be freshly installed! Enjoy!
639 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
345 961 Репутация
Автор 921 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 65 879 руководств
76 Комментарии к руководству
I replace Toshiba MK1231Gal dard disk based on instruction on yutube http://www.youtube.com/watch?feature=pla...!
the problem is that when I try to install osx, I cant format the disk
I got notice input, output error, when try to make a partition or try anything with disk utility
I own MacBook air 1237
Iztok - Ответить Поделиться
yes, me too...did you get it fix? please share how.
jay zee - Ответить Поделиться
Use disk utilities from the Mac OS installer to format the new drive in a Mac format. Then install the Mac OS. New drive won’t show up in the installer until it’s Mac format.
littleduckltd - Ответить Поделиться
DDD in this case
dard disk
Ben Capehart - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 40
За последние 7 дней: 346
За последние 30 дней: 1,932
За всё время: 1,959,187
