Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Remove the following screws from the port side of rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Remove the single 12 mm Phillips screw securing the top of the rear speaker housing to the upper case.
Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
Use the flat end of a spudger to pry the rear speaker connector up off the logic board.
Carefully rotate the rear speaker assembly (with AirPort/Antenna cables still attached) out of the lower case.
Use the flat end of a spudger to pry the optical drive connector up off the logic board.
Remove the single 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
Remove the two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Pull the optical drive cable connector away from the body of the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
69 участников успешно повторили данное руководство.
10 Комментариев
Step 4-5 There is a screw in the center of the bar that looks like it might not be a hold down. It is. Be sure to remove it along with the other screws at each end of the bar per step 4 & 5 instructions.
Step 4-5
There is a screw in the center of the bar that must be removed, in addition to the screws noted in the instructions for step 4 and step 5. It looks like the bar might go over the screw. It doesn't. The center screw holds the bar down. Remove it.
