Выберете то, что вам нужно
Here is one of the vintage computers in my possession. It is a Macintosh Classic II M4150. Apple considers this obsolete and " information about these products is no longer updated as of 9/1/98 "
On powering it up, It originally greeted me with a checkerboard pattern that quickly converted into this pattern. The checkerboard pattern is/was commonly caused by bad Ram memory. Considering the age of this computer, leaking capacitors are a strong possibility. Time to check.
The cover is held in place by four (4) T-15 screws. Two (2) on the bottom
and two (2) under the top (handle)
The bottom ones are easy to remove
The top ones are a bit of a challenge due to the depth of the holes.
There was just not enough room to get a good grip on the driver.
Luckily this iFixit driver has a hole on the top part. I used a tool to gain some mechanical advantage. While applying downward pressure on the driver, turn the tool to the left to loosen the screw
Once loosened, the iFixit extension that came with my set, works perfectly to remove the screw,
Here are the four (4) screws. The two bottom screws are M4X15mm The top screws are those typical found in plastic to sheet metal joints.
With the screws removed the cover will slide off.
BEst practice is to lay it down and pull the case straight up. It may take some force due to the tight fit and years of storage etc.
Here is what the inside looks like.
Power supply (Sweep Board)
Flyback Transformer
Video card
CRT
SCSI Hard drive
Hard drive on top with the Floppy drive on the bottom
Here is the Hard Drive. It is actually mounted upside down. You are looking at the drive controller board
Remove the power cable
Next remove the data cable. The red stripe always connects to pin 1 of the connector
To remove the cable, simply pull it toward the back. No locking tabs etc. on these.
There are two (2) Philips head screws that hold the HDD caddy. Remove those
The screws are M3 by 8mm machine screws
With the two (2) screws removed, simply remove the Hard Drive with caddy out of the chassis.
The drive is a Quantum ProDrive LPS 42S 40GB SCSI Hard Drive - Apple 940-40-9404
Еще один человек закончил это руководство.
