Введение
This guide will illustrate how to replace the device's antenna.
Выберете то, что вам нужно
Place the GPS with the screen facing down.
Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
Insert the black spudger into the crease in the side of the GPS.
Move the end of the spudger down to break the seal between the two plastic shells.
Continue doing this along each side of the GPS to ensure a smooth removal.
Fully separate the two sides of the case.
Remove the tape on the battery wires and the tape on the speaker wires.
Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
Identify the antenna.
Locate the two screws in the antenna.
Use a Phillips #0 screwdriver to remove the two 2.5mm Phillips #0 screws.
After the screws have been removed, move the motherboard so that it is sitting in the side with the speaker and battery.
Using a soldering iron, melt the solder connecting the antenna to the motherboard. For instructions on how to use the soldering iron, refer to Soldering Technique Guide for instructions.
