Введение
This guide will show you how to remove and replace the motherboard inside your Magellan Roadmate 5250T-LM. It would be helpful to know how to solder before attempting this replacement. To remove the motherboard you must desolder it from the battery and speakers. After this, you will need to solder your new motherboard back on to the battery and speakers.
Выберете то, что вам нужно
Remove all four 5mm screws from the back of the device using a Phillips Head screwdriver size 000.
Remove the motherboard from the device by unscrewing all three 4mm screws that are connecting it to the casing with a Phillips Head screwdriver size 000.
Disconnect the original battery from the motherboard and the speaker by desoldering all five wires that attach them to the motherboard.
