Magic Bullet NutriBullet Rubber Gasket Replacement
Выберете то, что вам нужно
  1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: шаг 1, изображение 1 из 1
    • Separate the blending blade lid from the cup.
  2. Magic Bullet NutriBullet Rubber Gasket Replacement: шаг 2, изображение 1 из 2 Magic Bullet NutriBullet Rubber Gasket Replacement: шаг 2, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
    • Slowly pry the rubber gasket up.
Заключение
Еще один человек закончил это руководство.
Geary Yu
Участник с: 01/22/15
1 268 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 19-8, Maness Winter 2015 Участник Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 членов
Автор 13 руководств
11 Комментарии к руководству
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - Ответить Поделиться
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - Ответить Поделиться
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - Ответить Поделиться
Thanks a lot.
Kayla Martin - Поделиться
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 46
За последние 30 дней: 160
За всё время: 37,882
