Making Visible the Users Library Directory in OS X Lion
Архивированное руководство
Это руководство сохранено для исторических целей. Используйте его обновлённую версию, чтобы выполнить ремонт.
  1. Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: шаг 1, изображение 1 из 2 Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: шаг 1, изображение 2 из 2
    • Many Macintosh users were excited when OS X 10.7 (Lion) was released, but after using it for a short time, many users realized that something was missing from lion.
    • The users Library directory is not where it it should be, infact, it is nowhere to be found. Fortunately, it is very simple to bring back the disappearing Library.
    Спросите у FixBot
  2. Making Visible the Users Library Directory in OS X Lion: шаг 2, изображение 1 из 1
    • To begin the process, you will need to go to your Applications folder, which can be found in your Finder side bar.
    • Once in the Applications folder, you will want to find the Utilities folder.
    Спросите у FixBot
  3. Making Visible the Users Library Directory in OS X Lion: шаг 3, изображение 1 из 1
    • After navigating to the Utilities folder you will need to scroll down to find the Terminal application.
    Спросите у FixBot
  4. Making Visible the Users Library Directory in OS X Lion: шаг 4, изображение 1 из 2 Making Visible the Users Library Directory in OS X Lion: шаг 4, изображение 2 из 2
    • Once you have opened Terminal, you will need to type chflags nohidden ~/Library/ and then press Enter.
    • This will immediately make your Library folder visible under your user.
    Спросите у FixBot
  5. Making Visible the Users Library Directory in OS X Lion: шаг 5, изображение 1 из 1
    • Once you have finished with Terminal, type exit to end your terminal processes. After you have typed this and hit enter you may quit out of Terminal.
    Спросите у FixBot
  6. Making Visible the Users Library Directory in OS X Lion: шаг 6, изображение 1 из 1
    • To hide the Library folder, simply type chflags hidden ~/Library and press Enter.
    • Remember to type exit and press Enter before quitting Terminal.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Owen Cunneely
Участник с: 12/01/10
7 187 Репутация
1 руководство автора
Команда
Master Techs Участник Master Techs
Community
333 членов
Автор 1 479 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 65
За всё время: 1,651
