Making a low cost photography light stand
Выберете то, что вам нужно
  1. Making a low cost photography light stand, Unplug the lamp: шаг 1, изображение 1 из 1
    • Before disassembling on the lamp, it MUST be unplugged!
  2. Making a low cost photography light stand, Remove the lightbulb: шаг 2, изображение 1 из 3 Making a low cost photography light stand, Remove the lightbulb: шаг 2, изображение 2 из 3 Making a low cost photography light stand, Remove the lightbulb: шаг 2, изображение 3 из 3
    • If the bulb is worth keeping, this can be reused.
    • If the lamp has a lightbulb installed, remove it from the lamp.
  3. Making a low cost photography light stand, Remove the socket cover: шаг 3, изображение 1 из 3 Making a low cost photography light stand, Remove the socket cover: шаг 3, изображение 2 из 3 Making a low cost photography light stand, Remove the socket cover: шаг 3, изображение 3 из 3
    • MOST LAMPS WILL BE SIMILAR, but designs can vary.
    • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
    • Remove the socket cover. Once removed, remove the bulb socket.
  4. Making a low cost photography light stand, Remove the bulb socket: шаг 4, изображение 1 из 2 Making a low cost photography light stand, Remove the bulb socket: шаг 4, изображение 2 из 2
    • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
    • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
    • Discard any broken or unwanted components.
  5. Making a low cost photography light stand, Remove the cord: шаг 5, изображение 1 из 3 Making a low cost photography light stand, Remove the cord: шаг 5, изображение 2 из 3 Making a low cost photography light stand, Remove the cord: шаг 5, изображение 3 из 3
    • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
    • After removing the bulb socket, remove the power cord.
  6. Making a low cost photography light stand, Test the lamp and find a good clamp point: шаг 6, изображение 1 из 1
    • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
Финишная черта
Nick
Участник с: 11/10/09
88 987 Репутация
Автор 50 руководств
Команда
Master Techs Участник Master Techs
Community
321 членов
Автор 1 468 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 461
