Makita Jack Hammer HM1307CB Cord Guard Replacement
Выберете то, что вам нужно
  1. Makita Jack Hammer HM1307CB Cord Guard Replacement, Remove six screws from the handle: шаг 1, изображение 1 из 1
    • Remove the following screws:
    • Two Phillips screws
    • Four hex screws
    • These four hex screws are all held in place with threadlocker, and may take quite a bit of torque or even some heat to loosen.
    • During reassembly, clean the residual threadlocker from these screws, then reapply high-strength (red) threadlocker to each one before reinstalling.
    • If you aren't sure how to apply threadlocker, refer to the next step in this guide.
  2. Makita Jack Hammer HM1307CB Cord Guard Replacement: шаг 2, изображение 1 из 3 Makita Jack Hammer HM1307CB Cord Guard Replacement: шаг 2, изображение 2 из 3 Makita Jack Hammer HM1307CB Cord Guard Replacement: шаг 2, изображение 3 из 3
    • To reapply threadlocker:
    • First, clean the residual threadlocker from each of the screws with some cleaner/degreaser and a stiff brush.
    • Second, apply a couple drops of high-strength threadlocker to the screw sockets.
    • Finally, apply one or two drops of the same high-strength threadlocker to the tip of each screw and reinstall them.
  3. Makita Jack Hammer HM1307CB Cord Guard Replacement, Remove the handle: шаг 3, изображение 1 из 2 Makita Jack Hammer HM1307CB Cord Guard Replacement, Remove the handle: шаг 3, изображение 2 из 2
    • Grab the handle and remove it from the jack hammer.
  4. Makita Jack Hammer HM1307CB Cord Guard Replacement, Release the power supply cord: шаг 4, изображение 1 из 1
    • Remove the black Phillips screw from the strain relief plate.
    • Loosen the two silver Phillips screws that hold the stripped ends of the power cable in the green terminal on the controller. These screws do not need to be removed.
  5. Makita Jack Hammer HM1307CB Cord Guard Replacement: шаг 5, изображение 1 из 2 Makita Jack Hammer HM1307CB Cord Guard Replacement: шаг 5, изображение 2 из 2
    • Remove the strain relief plate.
    • During reassembly, hook the right edge of the strain relief plate under the lip to the right of the cord before pressing it into place and reinstalling the Phillips screw.
  6. Makita Jack Hammer HM1307CB Cord Guard Replacement, Remove the power supply cord: шаг 6, изображение 1 из 3 Makita Jack Hammer HM1307CB Cord Guard Replacement, Remove the power supply cord: шаг 6, изображение 2 из 3 Makita Jack Hammer HM1307CB Cord Guard Replacement, Remove the power supply cord: шаг 6, изображение 3 из 3
    • Remove the power supply cord from the jack hammer.
    • As you remove the cord, note the position of the cord guard. During reassembly, make sure the collar of the cord guard fits back into its slot in the handle.
    • When reinserting the two exposed wire ends into the green terminal:
    • First, compress the wire ends so they are relatively flat.
    • Then, insert each wire end into the green terminal, noting the polarity of the cables: the black cable should go into the upper slot, and the white cable should go into the lower slot (as shown in the third photo of this step).
    • Finally, gently tighten the screws until the wires are secured.
  7. Makita Jack Hammer HM1307CB Cord Guard Replacement, Remove the cord guard: шаг 7, изображение 1 из 2 Makita Jack Hammer HM1307CB Cord Guard Replacement, Remove the cord guard: шаг 7, изображение 2 из 2
    • Slide the cord guard off of the power cord.
    • This may take some force—if your cord guard does not come off easily, try twisting as you pull.
Заключение
To reassemble your device, follow these instructions in reverse order, taking note of any reassembly tips.
Еще один человек закончил это руководство.
Taylor Dixon
Участник с: 06/26/18
67 317 Репутация
Автор 94 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 13
За всё время: 425
