Введение
Use this guide to replace the binding posts in your MartinLogan Motion 4i speaker.
The binding posts on speakers allows the speaker to connect to a power source using external wires. Binding posts that no longer operate will generally disable all functions of the speaker, because the speaker wouldn’t have power going to its internal operating systems. Oftentimes, if the binding posts don’t work, it will seem as if the speaker no longer works.
Make sure to check out our troubleshooting page to properly diagnose your MartinLogan Motion 4i before you begin this guide.
Before you begin this guide, be sure to remove all external wires and connections to a power source from the speaker to ensure a safe removal of all speaker components.
Выберете то, что вам нужно
Remove the speaker grill from the face of the speaker by using both hands to grip both ends of the speaker grill and pulling up to release the magnetic ends.
Remove the six caps from the outer edge of the face of the speaker with an iFixit opening tool.
Remove the six 4 mm Phillips #2 screws that are located inside each of the holes where the rubber caps used to be.
Lightly grip the material that insulates and covers the speaker components and remove it by pulling up.
Remove both wires that are connecting the back of the speaker to the components of the speaker to fully access the speaker components.
