Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement
Выберете то, что вам нужно
  1. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement, Tail/Reverse/Rear Turn Signal Bulb: шаг 1, изображение 1 из 1
    • The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
  2. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: шаг 2, изображение 1 из 1
    • The panel is secured with two thumb screws. Remove these.
  3. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: шаг 3, изображение 1 из 1
    • Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
  4. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: шаг 4, изображение 1 из 1
    • There are five bulbs in each tail light housing. They are as follows:
    • Brake light
    • Reverse light
    • Tail light
    • Turn signal
    • Side marker
  5. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: шаг 5, изображение 1 из 1
    • To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
  6. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: шаг 6, изображение 1 из 3 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: шаг 6, изображение 2 из 3 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: шаг 6, изображение 3 из 3
    • Three of the bulbs are #1156
    • One is a #96
    • One is a small 4W blub
  7. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: шаг 7, изображение 1 из 1
    • Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
Заключение
10 участников успешно повторили данное руководство.
Nicolas Siemsen
Участник с: 12/06/13
39 040 Репутация
Автор 79 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 535 руководств
2 Комментариев
Very informative, descriptive and point on analysis.
George T Peeke - Ответить
Und wie wird dies beim Kombi gemacht?
srossius - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 16
За последние 30 дней: 86
За всё время: 12,283
