Mercedes W123 Radiator Hose Replacement
Выберете то, что вам нужно
  1. Mercedes W123 Radiator Hose Replacement, Radiator Hose: шаг 1, изображение 1 из 1
    • Begin by draining your radiator of coolant as [недействительная ссылка на руководство]. You will not need to drain the block for this process.
    • As always, never work on your coolant system when it is hot. This is very very dangerous.
  2. Mercedes W123 Radiator Hose Replacement: шаг 2, изображение 1 из 2 Mercedes W123 Radiator Hose Replacement: шаг 2, изображение 2 из 2
    • Find your upper coolant hose connection at the upper driver's side of the radiator.
    • Loosen the hose clamp on this end of the hose.
  3. Mercedes W123 Radiator Hose Replacement: шаг 3, изображение 1 из 1
    • Follow this hose to the top of the engine block, where it enters the thermostat housing.
  4. Mercedes W123 Radiator Hose Replacement: шаг 4, изображение 1 из 1
    • Then use a hose clamp removal hook or other appropriate tools to work around under the edge of the hose. This will help break them free; they often stick to the necks they attach to over time.
    • Pull the hose off fully on both ends.
  5. Mercedes W123 Radiator Hose Replacement: шаг 5, изображение 1 из 1
    • Continue by loosening the clamp on the lower radiator hose where it connects to the thermostat housing.
  6. Mercedes W123 Radiator Hose Replacement: шаг 6, изображение 1 из 1
    • Then go underneath the car and loosen the clamp on the lower radiator hose where it connects to the radiator.
    • Remove the hose in the same manner you did the upper hose.
    • Now replace both hoses, and secure with hose clamps. Replace the hose clamps with new ones if they were difficult to open due to corrosion or stripped screw heads.
    • Finish by filling the system with coolant and bleeding the system as [недействительная ссылка на руководство]
Заключение
4 участников успешно повторили данное руководство.
Nicolas Siemsen
Участник с: 12/06/13
39 040 Репутация
Автор 79 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 535 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 26
За всё время: 6,270
