Meta Quest 2 test USB port
Выберете то, что вам нужно
    • Hi!
    • If your Meta Quest 2 does not connect via USB, or the connection only works via USB 2.0, the connector on the cable or chip on the motherboard may be damaged. Below, I will show you how to test (based on comparing two Meta Quests, one with issues in the USB part and the other with no issues).
    Спросите у FixBot
    Добавить комментарий
  1. Meta Quest 2 test USB port: шаг 2, изображение 1 из 1
    • You need a USB3.0 testing plat like this, and/or open the Oculus Quest 2 body like in this tutorial until step 6:
    • Oculus Quest 2 Disassembly
    Спросите у FixBot
    • If you insert the test board as shown in the photo, then: D- and D+ are the pins of the USB2.0 part of the connector; A2,A3 & A10,A11 & B2,B3 & B10,B11 are the TX and RX pairs of the USB3.0 part
    • The TX and RX pairs of USB 3.0 should be the same in both directions and A10-A11 & B10-B11 must be 600+\- during diode call in both directions
    Спросите у FixBot
  2. Meta Quest 2 test USB port: шаг 4, изображение 1 из 1
    • By disconnecting the connector from the board, you can see a picture as in the photo. The purple mark is the first pin of the connector. Let it be #1, and let it be #2 to the left, then:
    • #2 will be B11 & #3 will be B10
    • #5 will be A2 & #6 will be A3
    • #8 will be A10 & #9 will be A11
    • #11 will be B3 & #12 will be B2
    • In the second row, same counting from the right:
    • #4 will be D+ & #5 will be D-
    Спросите у FixBot
    • Four green strokes in the previous photo - these are the same A11-A10 and B11-B10 after the multiplexers (the most delicate and unprotected parts of the port - they damaged first)
    • There are no separation capacitors, as you can see (due to the required wire length).
    • If they get a supply voltage or a signal from the USB2.0 part - they burn out and stop diod calling mirrorily.
    • As far as I know, the damage is irreversible and occurs in the main chip on the board (repair is not advisable).
    Спросите у FixBot
Заключение
Dmitry
Участник с: 12/07/24
121 Репутация
1 руководство автора
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 39
За всё время: 629
