Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Metal snaps are essential for securely fastening heavy-duty fabrics on packs and jackets, such as those in the Patagonia Work Wear line. A metal snap can fail if it becomes crushed or is pulled off, requiring a new one to be installed.
This guide will demonstrate how to install a metal snap without the need for sewing. To ensure this solution is applicable, confirm that both sides of the damaged snap (the cap and the socket/stud) are visible. Additionally, check the fabric around the old snap for tears or damage beyond a small hole. If the fabric is compromised, a reinforcing patch will need to be sewn on before replacing the snap.
This guide is for professional repair technicians with access to a tabletop hand press.
Alternatively, Patagonia products can be taken to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
Related tutorial: Plastic Snap Installation Using a Hand Press
Выберете то, что вам нужно
Flat Spring Snap - This style is commonly found on clothing because it snaps and unsnaps smoothly.
Durable Socket Snap - This style is commonly found on packs and luggage because it has thicker metal that can withstand heavy use.
Gather the stud and post pieces and their corresponding dies.
Insert the post piece into the post die so the flat part of the post sits inside the die with the shaft pointed out.
Insert the post die into the lower fitting of the hand press.
Insert the stud piece into the stud die until it snaps into place.
Using your fingers, a screwdriver, or a hex key, as needed, unscrew the tightening mechanism on the side of the press near the die fitting.
Insert the die upward and hold it in place.
Tighten the tightening mechanism.
Lay the item to be repaired into the hand press so that the hole from the original snap rests directly above the shaft of the post.
Make sure no extra fabric is caught inside the press and that the orientation of the item is correct.
Hold the fabric in place with one hand, then use your other hand to pull down the handle of the press.
Release the handle of the hand press and remove the fabric.
Inspect both sides of the snap to make sure:
It's laying flat and tight up against the fabric.
It doesn't spin in place.
It fastens together securely with the head of the snap.
If the snap isn't set all the way, reinsert the snap into the hand press, aligning it as it was before, and pull the handle again.
Gather the socket and cap pieces and their corresponding dies.
Insert the cap piece into the cap die so it sits inside the die with the shaft facing out.
Insert the cap die into the lower fitting of the hand press.
Insert the socket piece into the socket die until it snaps into place.
It fastens together securely with the base of the snap.
The rain jacket in the first photo has flat spring metal snaps along the center front zipper placket.
The duffel bag in the second photo has durable socket metal snaps at the handle grip.
3 человек успешно провели ремонт по этому руководству.
