MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement
Выберете то, что вам нужно
  1. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: шаг 1, изображение 1 из 3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: шаг 1, изображение 2 из 3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: шаг 1, изображение 3 из 3
    • There are two versions of the unloader assembly:
    • First image—earlier pressure washers feature an all-in-one assembly (part 8-0631) that’s easy to replace, but gave users the ability to break the pump.
    • Second image—later models use a tamper-proof, harder to remove unloader (part 8-0656), connected by a series of pipe fittings.
    • This guide is written for the tamper-proof unloader assembly.
    • If you need to remove an all-in-one style unloader, use a large adjustable wrench to unscrew the two large Banjo bolts. This will disconnect the unloader from the pump assembly.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: шаг 2, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: шаг 2, изображение 2 из 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the hose clamp: шаг 3, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the hose clamp: шаг 3, изображение 2 из 2
    • Use a 1/4" socket or a large flathead screwdriver to loosen the hose clamp near the inlet filter.
    • Slide the hose clamp away from the end of the hose.
  4. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Disconnect the return hose: шаг 4, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Disconnect the return hose: шаг 4, изображение 2 из 2
    • Wiggle the hose and pull it off of the brass nipple.
  5. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Position the support block: шаг 5, изображение 1 из 1
    • Slide a 3" tall block underneath the pump assembly to help support the pump.
  6. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Re-position the return elbow: шаг 6, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Re-position the return elbow: шаг 6, изображение 2 из 2
    • Use a 1/2" or adjustable wrench to loosen and twist the return elbow half a turn, so that it faces the opposite direction.
    • This will allow the fitting to clear the pump edge without being removed.
  7. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the filter: шаг 7, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the filter: шаг 7, изображение 2 из 2
    • Use a large adjustable wrench to loosen and unscrew the filter.
  8. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the filter: шаг 8, изображение 1 из 1
    • Remove the filter with the return elbow attached.
  9. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the input elbow: шаг 9, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the input elbow: шаг 9, изображение 2 из 2
    • Use a 1" or large adjustable wrench to loosen and unscrew the pump input elbow.
  10. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the input elbow: шаг 10, изображение 1 из 1
    • Remove the input elbow fitting.
  11. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output assembly: шаг 11, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output assembly: шаг 11, изображение 2 из 2
    • Use a 3/4" or adjustable wrench to loosen and disconnect the coupling from the pump assembly.
  12. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the output assembly: шаг 12, изображение 1 из 1
    • Remove the output assembly.
  13. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Clamp the output assembly: шаг 13, изображение 1 из 1
    • You will need to remove the remaining fittings from the output assembly in order to replace the unloader.
    • Secure the output assembly in a large vise.
  14. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: шаг 14, изображение 1 из 3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: шаг 14, изображение 2 из 3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: шаг 14, изображение 3 из 3
    • Hold the outlet fitting in place with a 15/16" or large adjustable wrench.
    • Use a 3/4" or adjustable wrench to loosen and unscrew the output elbow from the outlet fitting.
  15. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: шаг 15, изображение 1 из 1
    • Remove the output elbow with the quick-connect socket attached to it.
  16. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the coupling nipple: шаг 16, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the coupling nipple: шаг 16, изображение 2 из 2
    • Use a 3/4" or adjustable wrench to loosen and unscrew the coupling nipple from the unloader.
  17. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the coupling nipple: шаг 17, изображение 1 из 1
    • Remove the coupling nipple.
  18. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the return hose nipple: шаг 18, изображение 1 из 2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the return hose nipple: шаг 18, изображение 2 из 2
    • Use a 11/16" or adjustable wrench to loosen and unscrew the return hose nipple from the unloader.
    • You do not need to disconnect the hose from the nipple.
  19. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the return hose: шаг 19, изображение 1 из 1
    • Remove the return hose nipple with the hose attached.
  20. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: шаг 20, изображение 1 из 3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: шаг 20, изображение 2 из 3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: шаг 20, изображение 3 из 3
    • Only the unloader assembly remains.
    • Compare the original unloader with the replacement part. The replacement part may have a plug installed in the wrong port.
    • Use an 8 mm (5/16" OK) hex key to remove and re-install the plug into the correct port.
Заключение
When you re-connect the fittings, clean off the old thread sealant and apply new thread sealant (tape or pipe dope).
4 участников успешно повторили данное руководство.
Arthur Shi
Участник с: 01/03/18
253 295 Репутация
Автор 526 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 163 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 20
За последние 30 дней: 40
За всё время: 1,073
