Microsoft Surface Pro 2 Fan Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Pro 2 Fan Replacement, LCD Display: шаг 1, изображение 1 из 2 Microsoft Surface Pro 2 Fan Replacement, LCD Display: шаг 1, изображение 2 из 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 Fan Replacement: шаг 2, изображение 1 из 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 Fan Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 Fan Replacement: шаг 4, изображение 1 из 3 Microsoft Surface Pro 2 Fan Replacement: шаг 4, изображение 2 из 3 Microsoft Surface Pro 2 Fan Replacement: шаг 4, изображение 3 из 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
  5. Microsoft Surface Pro 2 Fan Replacement, Motherboard: шаг 5, изображение 1 из 3 Microsoft Surface Pro 2 Fan Replacement, Motherboard: шаг 5, изображение 2 из 3 Microsoft Surface Pro 2 Fan Replacement, Motherboard: шаг 5, изображение 3 из 3
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
  6. Microsoft Surface Pro 2 Fan Replacement: шаг 6, изображение 1 из 3 Microsoft Surface Pro 2 Fan Replacement: шаг 6, изображение 2 из 3 Microsoft Surface Pro 2 Fan Replacement: шаг 6, изображение 3 из 3
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
  7. Microsoft Surface Pro 2 Fan Replacement: шаг 7, изображение 1 из 3 Microsoft Surface Pro 2 Fan Replacement: шаг 7, изображение 2 из 3 Microsoft Surface Pro 2 Fan Replacement: шаг 7, изображение 3 из 3
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
  8. Microsoft Surface Pro 2 Fan Replacement, Heat Sinks: шаг 8, изображение 1 из 3 Microsoft Surface Pro 2 Fan Replacement, Heat Sinks: шаг 8, изображение 2 из 3 Microsoft Surface Pro 2 Fan Replacement, Heat Sinks: шаг 8, изображение 3 из 3
    • Be sure to use gloves or tools because metal is sharp along the edge.
    • On the underside of the motherboard locate the heat shield which is located between the two fans near the top of the motherboard.
    • Remove the heat shield using an opening pick by lifting along the edges.
    • Remove all four Torx T5 screws located in each corner of the heat sink mounting frame.
    • Carefully lift off the heat sinks from the motherboard.
    • During reinstallation of the heat sinks, be sure to clean both contact surfaces with isopropyl alcohol and reapply thermal paste.
  9. Microsoft Surface Pro 2 Fan Replacement, Fan: шаг 9, изображение 1 из 3 Microsoft Surface Pro 2 Fan Replacement, Fan: шаг 9, изображение 2 из 3 Microsoft Surface Pro 2 Fan Replacement, Fan: шаг 9, изображение 3 из 3
    • On the top side of the motherboard, remove the three Torx T5 screws that secure each of the two fans to the motherboard.
    • Remove the ribbon cables that connect the fans to the motherboard from their clamps.
    • The ribbon cables are fragile and are prone to damage if too much force is used.
    • Remove the fans through the underside of the motherboard.
Заключение
3 человек успешно провели ремонт по этому руководству.
Skyler Addy
Участник с: 10/02/19
154 Репутация
1 руководство автора
1 Комментарий к руководству
very thorough- well done
Gray R - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 4,570
