Microsoft Surface Pro 2 Heat Sinks Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Pro 2 Heat Sinks Replacement, LCD Display: шаг 1, изображение 1 из 2 Microsoft Surface Pro 2 Heat Sinks Replacement, LCD Display: шаг 1, изображение 2 из 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 2, изображение 1 из 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 4, изображение 1 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 4, изображение 2 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 4, изображение 3 из 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
  5. Microsoft Surface Pro 2 Heat Sinks Replacement, Motherboard: шаг 5, изображение 1 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement, Motherboard: шаг 5, изображение 2 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement, Motherboard: шаг 5, изображение 3 из 3
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
  6. Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 6, изображение 1 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 6, изображение 2 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 6, изображение 3 из 3
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
  7. Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 7, изображение 1 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 7, изображение 2 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement: шаг 7, изображение 3 из 3
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
  8. Microsoft Surface Pro 2 Heat Sinks Replacement, Heat Sinks: шаг 8, изображение 1 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement, Heat Sinks: шаг 8, изображение 2 из 3 Microsoft Surface Pro 2 Heat Sinks Replacement, Heat Sinks: шаг 8, изображение 3 из 3
    • Be sure to use gloves or tools because metal is sharp along the edge.
    • On the underside of the motherboard locate the heat shield which is located between the two fans near the top of the motherboard.
    • Remove the heat shield using an opening pick by lifting along the edges.
    • Remove all four Torx T5 screws located in each corner of the heat sink mounting frame.
    • Carefully lift off the heat sinks from the motherboard.
    • During reinstallation of the heat sinks, be sure to clean both contact surfaces with isopropyl alcohol and reapply thermal paste.
Заключение
Еще один человек закончил это руководство.
Ryan Charles Skibicki
Участник с: 10/02/19
145 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 928
