Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace the battery pack in the Microsoft Surface Pro.
Выберете то, что вам нужно
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Apply a suction cup as close as possible to the edge of the display.
Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
Before completely removing the display, disconnect the three display cables.
Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
Remove the 6 T5 screws from the panels on each side of the frame.
Remove 23 T2 screws from the panels.
Unscrew the 17 T5 torx screws on the mother board with the T5 torx screw driver
Once all screws are removed, gently lift up the logic board with your hands to pull it out.
Use your hands to pry off the entire battery pack with enough force to overcome the glue keeping the batteries in place.
35 участников успешно повторили данное руководство.
24 Комментариев
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
I am also trying to find out where to acquire the Surface Pro batteries...???
im also looking for a surface pro replacement battery.
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt -
