Введение
Use this guide to remove the motherboard in the Motorola Moto E4 Plus (XT1771).
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before disassembling your phone, discharge the battery below 25%. If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
Выберете то, что вам нужно
Insert the edge of the spudger into the notch on the bottom right corner of the phone.
Twist the spudger to start releasing the back cover from the phone.
Slide the spudger along the bottom edge to separate the back cover from the phone.
Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
Insert an opening pick underneath the bottom left corner of the motherboard cover.
Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
Insert an opening pick underneath the bottom right corner of the motherboard cover.
Use the opening pick to pry up the motherboard cover.
Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
Use the flat end of a spudger to pry up and disconnect the interconnect flex cable.
Use the tip of a spudger or an opening pick to pry up the flap of the ZIF connector, located in the bottom right corner of the motherboard.
Use a pair of tweezers to pull the display flex cable out of the ZIF connector.
Grasp the motherboard by the top corners and remove it by lifting up and pulling it carefully out of its recess.
Use the flat end of a spudger to pry up and disconnect the front facing camera flex cable.
Remove the front facing camera with a pair of tweezers.
Use the flat end of a spudger to pry up and disconnect the rear facing camera flex cable.
Remove the rear facing camera with a pair of tweezers.
13 участников успешно повторили данное руководство.
2 Комментариев
Excellent guide. Keep going. I have an another request from you, could you show the repairing or replacing bluetooth, wifi, hotspot sensor with this same moto e4 plus? Bcus its not working in my mobile. I am getting pop up like “Bluetooth isn’t responding” Please guide us!
Moto e4plus has been fall into water and sshot what to do
