Введение
Use this guide to remove the rear camera in the Motorola Moto E4 Plus (XT1771).
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before disassembling your phone, discharge the battery below 25%. If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
Выберете то, что вам нужно
Insert the edge of the spudger into the notch on the bottom right corner of the phone.
Twist the spudger to start releasing the back cover from the phone.
Slide the spudger along the bottom edge to separate the back cover from the phone.
Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
Insert an opening pick underneath the bottom left corner of the motherboard cover.
Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
Insert an opening pick underneath the bottom right corner of the motherboard cover.
Use the opening pick to pry up the motherboard cover.
Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
Fold the copper tape out of the way.
Use the flat end of a spudger to pry up and disconnect the rear camera flex cable.
If possible, turn on your phone and test your repair before reassembly.
5 участников успешно повторили данное руководство.
