Введение
This guide demonstrates how to remove and replace the main camera in your 2022 Motorola Moto G.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Выберете то, что вам нужно
Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
Press firmly to eject the tray.
Take note of the following seams along the edge of the phone:
Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
Insert an opening pick in the gap you just created.
Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
Slide your opening pick toward the top left corner to unclip the left side of the back cover.
Slide your pick around the top left corner and along the top edge to release the clips.
Slide your pick around the top right corner to release the last clips securing the back cover.
With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
Rest the cover parallel to the frame.
Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
Insert an opening pick between the bottom-left corner of the cover and the motherboard.
Pry up to release the cover's small clips securing it to the frame.
Инструмент, используемый на этом этапе:Tweezers$4.99
Grab and remove the motherboard cover from the phone.
Use the pointed end of a spudger to pry and disconnect the battery's press connector.
Peel the tape from the display connector.
Use the pointed end of a spudger to pry and disconnect the screen's press connector.
Fold the graphite heat film away from the battery to expose the lower section of the motherboard.
Use the pointed end of a spudger to pry and disconnect the board cable's press connector.
Use the pointed end of your spudger to pry and disconnect the head of the black antenna cable.
Free the cable from the clip below the head of the connector.
Repeat the previous step for the white antenna cable.
Use your Phillips screwdriver to remove the 2.9 mm-long screw from the bottom-right corner of the motherboard.
Insert the pointed end of a spudger between the lower left of the motherboard and the frame.
Lift upward on this bottom edge to free the motherboard from the frame.
Grab the motherboard from the bottom edge and lift it from its recess.
Flip the motherboard over so that the lens of the main camera is facing down.
Use the pointed end of your spudger to pry and disconnect the main camera's press connector.
Remove the main camera from the motherboard.
Еще один человек закончил это руководство.
Один комментарий
Really enjoyed using your ifixit. This made it very easy to replace the camera in my Moto G. Great pictures and descriptions. My Moto G Power was a little different with a fingerprint scanner on the back and integrated side buttons in the frame. The back cover couldn't be folded out of the way until the scanner was disconnected, which couldn't be done until the MOBO cover was removed. Would like to send a pic to show.
