Введение
This guide will show each detailed step to removing and replacing the front display screen in the Motorola G7 Play, model number XT1952-3 or XT1952-2. If the phones touch functionality is faulty, the screen is cracked, or not displaying correctly the screen can be replaced. This guide requires a heat gun or heating application on the screen.
Выберете то, что вам нужно
Use the plastic opening tools or picks to create an gap between the screen and the rest of the device.
Use the suction cup tool to lift the screen without damaging or scratching screen.
Disconnect the ribbon cable to fully detach the screen from the device.
Remove the display assembly from the device.
3 участников успешно повторили данное руководство.
2 Комментариев
I agree with Ender, this is the farthest thing from instructions on how to replace the screen. It’s just photos of how someone pulled the display off the frame. I can’t think of a reason anyone would do this. What’s the point?
Can we take away 30 points?
