Введение
The Motorola Moto G7 Plus (model XT1965) features a 3000 mAh Li-Ion battery. If a user has had the phone for a long time, the phone will lose its charge at a much faster rate than when it was new and the battery may need to be replaced. If troubleshooting doesn’t work, use this guide to remove the battery from the Motorola Moto G7 Plus.
This guide teaches how to remove the battery with a prerequisite for taking out the screen. This guide minimizes the number of steps a user would have to take to replace the battery.
Before beginning the repair, make sure the device is turned off and disconnected from any external power sources. Gather the suggested tools listed below and a new Motorola Moto G7 Plus battery.
Запчасти
Insert an opening pick under the screen, starting at the top of the phone.
Work the pick along the edges of the phone, removing adhesive from these parts of the screen.
Once enough adhesive has been removed, you should be able to separate the screen, gently lifting from the left side of the phone.
Remove the three 2.7 mm screws that surround the base of the cable using the Torx T5 screwdriver.
Once the screws have been removed, gently remove the metal piece that covers the base of the cable.
Underneath this metal piece is the base of the cable. Use your pick or spudger to pop off the base of the cable.
The screen will be detached from the device.
Use the blade end of a Halberd Spudger to cut through the two strips of black tape attached to the battery.
Use the flat end of the spudger to disconnect the battery from the phone.
2 участников успешно повторили данное руководство.
