Введение
This guide will show you how to install the Motorola Razr V3 camera. You may need to install a new camera if the camera doesn't show any picture or otherwise does not work.
Выберете то, что вам нужно
Видеообзор
Remove the back cover by pressing down the silver button.
Pull the cover away from the phone.
Remove the battery by pushing down on the top and pulling it away from the phone.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to pry off the four rubber screw covers from the inside face.
Use tweezers to flip up the ZIF tab on the camera ribbon cable socket.
Gently pull the camera ribbon cable out of the ZIF socket.
2 человек успешно провели ремонт по этому руководству.
