Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Leaks can occur within the Mr. Coffee TF6. In most cases, replacing the internal water tubes will correct this issue. You will require 2 inches of silicone tubing (.5 in. OD) to replace the original water tubes inside the TF6.
Выберете то, что вам нужно
Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
Еще один человек закончил это руководство.
