Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
Pry the cube face from the frame.
After removing the square plates, you can unscrew the screws underneath.
Remove four 6 mm Phillips #2 screws, located on the sides.
Remove twenty-four 6 mm Phillips #2 from all 6 sides.
Once the screws are removed, gently pull apart the frame.
Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up.
Use the Jimmy to remove the glue connecting the motherboard to the white frame.
Use the soldering iron to desolder the LED by applying heat to the half sphere like connections.
Еще один человек закончил это руководство.
