Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Batteries power the laser. If the laser is not working, one of the reasons might be the batteries. Follow the steps in this guide to correctly replace the batteries.
Выберете то, что вам нужно
The batteries are located in the handle of the blaster.
The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
