Введение
This guide will demonstrate how to remove the capacitors in order to replace them. Soldering and de-soldering will be required.
Выберете то, что вам нужно
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Turn the motherboard so that the top is facing upwards.
Place the motherboard on a clean flat surface.
Turn the motherboard so that the bottom is facing upwards.
Locate the two soldered contacts for each capacitor.
Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
Еще один человек закончил это руководство.
1 Комментарий к руководству
my router NETGEAR WNR 612 WIFI LED NOT GLOWING PLEASE HLP ME IN REPAIRING
