Nabi Jr Battery Replacement
Выберете то, что вам нужно
  1. Nabi Jr Battery Replacement, Rear Case: шаг 1, изображение 1 из 1
    • Remove the red rubber case from the device. This should come off with ease.
    Спросите у FixBot
    Добавить комментарий
  2. Nabi Jr Battery Replacement: шаг 2, изображение 1 из 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
    Спросите у FixBot
  3. Nabi Jr Battery Replacement: шаг 3, изображение 1 из 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
    Спросите у FixBot
  4. Nabi Jr Battery Replacement: шаг 4, изображение 1 из 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
    Спросите у FixBot
  5. Nabi Jr Battery Replacement, Battery: шаг 5, изображение 1 из 1
    • Lift the battery up from the motherboard.
    • Don't rip the soldered wires from the board.
    • The battery is stuck to the motherboard with adhesive, it may take a little pull to separate.
    Спросите у FixBot
  6. Nabi Jr Battery Replacement: шаг 6, изображение 1 из 1
    • Remove the battery from the motherboard
    • De-solder the colored wires
    • Be sure to note the order in which the wires are connected to the board before desoldering them.
    • Be careful while removing the solder off of the colored battery wires. The soldering iron will be extremely hot
    Спросите у FixBot
  7. Nabi Jr Battery Replacement: шаг 7, изображение 1 из 2 Nabi Jr Battery Replacement: шаг 7, изображение 2 из 2
    • Replace the old battery with the new one
    • Solder the wires of the new battery into the pads on the motherboard
    • Be careful when soldering the wires in. Soldering iron will be extremely hot
    Спросите у FixBot
  8. Nabi Jr Battery Replacement: шаг 8, изображение 1 из 1
    • Once the wires are fully soldered, put the new battery back to the initial position
    • Close the case by putting the back cover back on the device
    • Will take some force
    • Make sure the battery is not in the way of the back cover
    Спросите у FixBot
  9. Nabi Jr Battery Replacement: шаг 9, изображение 1 из 1
    • Once the back cover is on, screw in the four screws that you had taken off in the beginning
    • Put the red rubber casing back on.
    Спросите у FixBot
Заключение
If all the steps were followed correctly, the device should be fully closed and ready to go
4 человек успешно провели ремонт по этому руководству.
Jimmy Nguyen
Участник с: 03/24/15
271 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Участник UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
3 членов
Автор 12 руководств
7 Комментарии к руководству
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
Lus Ka - Ответить Поделиться
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
darcshadow - Ответить Поделиться
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
Dennis Blixt - Ответить Поделиться
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
Delores Duke - Ответить Поделиться
Where can I buy the battery live in Mexico
Roos - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 47
За всё время: 12,336
