Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
In this guide, you will be able to easily find and replace the trigger spring for the Nerf Dart Tag Swarmfire.
Выберете то, что вам нужно
Place the Nerf gun on its side and loosen all nine screws so the device can be opened.
Avoid the fake plastic screw, which is merely decorative.
Remove the yellow and blue plastic covers from the Nerf gun to display the Nerf gun's motherboards and motor.
Locate the orange trigger (dark blue if it's the newer version).
Slide trigger out of place and check the spring.
If it is damaged, pull the spring off the trigger.
Push the new trigger spring onto the trigger
Make sure the trigger catches the small trigger notch so it doesn't fall off
Put the trigger back into place with the trigger spring pressed into the small compartment.
Еще один человек закончил это руководство.
