Введение
If your Nest Cam IQ camera has lost clear viability, you most likely have a cracked camera lens, which Requires replacement.
A functional camera provides a clear view. If you notice poor camera quality or lines when pulling up Nest Cam IQ recordings, consider changing out your camera.
Выберете то, что вам нужно
To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
Leave the iOpener on the glass lens for two minutes.
Place a suction cup on the glass lens that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
Pull off the glass lens using the suction cup.
Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
Remove the metal plate.
Remove the five 9 mm TR6 Torx screws from the LED cover.
Pull off the LED cover.
Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
Remove the LED cover.
Remove the two 7 mm TR6 Torx screws securing the camera.
Carefully pull out the camera.
Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
Remove the camera.
Еще один человек закончил это руководство.
