Nest Cam IQ Mounting Stand Replacement
Выберете то, что вам нужно
  1. Nest Cam IQ Mounting Stand Replacement, Mounting Stand: шаг 1, изображение 1 из 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the Opener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the Opener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Mounting Stand Replacement: шаг 2, изображение 1 из 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Mounting Stand Replacement: шаг 3, изображение 1 из 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Mounting Stand Replacement: шаг 4, изображение 1 из 2 Nest Cam IQ Mounting Stand Replacement: шаг 4, изображение 2 из 2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Mounting Stand Replacement: шаг 5, изображение 1 из 2 Nest Cam IQ Mounting Stand Replacement: шаг 5, изображение 2 из 2
    • Remove the five 9mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Mounting Stand Replacement: шаг 6, изображение 1 из 3 Nest Cam IQ Mounting Stand Replacement: шаг 6, изображение 2 из 3 Nest Cam IQ Mounting Stand Replacement: шаг 6, изображение 3 из 3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Mounting Stand Replacement: шаг 7, изображение 1 из 1
    • Remove the two 7mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Mounting Stand Replacement: шаг 8, изображение 1 из 2 Nest Cam IQ Mounting Stand Replacement: шаг 8, изображение 2 из 2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
  9. Nest Cam IQ Mounting Stand Replacement: шаг 9, изображение 1 из 3 Nest Cam IQ Mounting Stand Replacement: шаг 9, изображение 2 из 3 Nest Cam IQ Mounting Stand Replacement: шаг 9, изображение 3 из 3
    • Remove the three 19mm TR6 Torx screws from the camera holder.
    • Carefully lift the tab up and away from the camera holder.
    • Remove the camera holder.
  10. Nest Cam IQ Mounting Stand Replacement: шаг 10, изображение 1 из 2 Nest Cam IQ Mounting Stand Replacement: шаг 10, изображение 2 из 2
    • Remove the one 4mm TR6 Torx screw from the clear cover.
    • Remove the clear cover.
  11. Nest Cam IQ Mounting Stand Replacement: шаг 11, изображение 1 из 3 Nest Cam IQ Mounting Stand Replacement: шаг 11, изображение 2 из 3 Nest Cam IQ Mounting Stand Replacement: шаг 11, изображение 3 из 3
    • Remove the four 11mm TR6 Torx screws from the clamp securing the mounting stand.
    • Remove the clamp.
    • Carefully pull away the cables connecting the mounting stand to the body.
  12. Nest Cam IQ Mounting Stand Replacement: шаг 12, изображение 1 из 1
    • Carefully remove the mounting stand.
Заключение
Еще один человек закончил это руководство.
Jas Ownby
Участник с: 09/08/23
800 Репутация
Автор 4 руководств
Команда
University of New Orleans, Team 5-5, McDonald Fall 2023 Участник University of New Orleans, Team 5-5, McDonald Fall 2023
UNO-MCDONALD-F23S5G5
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 70
