Введение
If your Nest x Yale Lock is related to any issues on the unresponsive section of our troubleshooting page, you may need to replace the motherboard. Use this guide to replace the motherboard properly.
The motherboard is located inside and responsible for the lights, locking the lock, connecting the keypad, and helping the whole lock function.
Before beginning the process, be sure the device is off and not connected to the keypad.
Выберете то, что вам нужно
Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
Remove 3 screws as shown to remove the first cover.
The 3 screws are 0.25 inches length
Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
Continue to remove 2 screws holding the motherboard to the lock shell.
The screws are 0.20 inches in length.
