Введение
The battery of the NeuTab Air7 is a vital component that stores all of the electrical power within the device. Without it, your tablet would be unable to function, which is why handling of this component requires a delicate hand. Follow this guide to ensure successful replacement.
Выберете то, что вам нужно
Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
Remove any adhesive tape that is holding the wires protruding from the battery down.
De-solder the red and black wire ends that connect the battery to the motherboard.
Wedge a plastic or nylon spudger underneath the battery, moving it back and forth to separate it from the device.
Remove the battery.
