Введение
The speaker is responsible for the audio outputs of the device. Issues with this component can range from distorted audio, to poor quality audio in general, to even total failure to function. Being such a core component to daily operations, it is imperative to ensure successful installation of any new speaker. In order to perform successful replacement of the component, follow this guide.
Выберете то, что вам нужно
Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
De-solder the red and black wire ends that connect the speaker to the motherboard.
Use a Phillips #00 screwdriver to remove the two 0.8 mm screws holding the cover of the speaker in place.
Remove the cover and the speaker.
