Введение
In this guide we will be removing the motherboard. The motherboard is a circuit board that contains the main components of the tablet. It connects the main accessories like the camera, battery, and screen. By following this guide, you will be able to successfully replace your motherboard on your NeuTab N7 Pro Tablet.
Выберете то, что вам нужно
Power off you device before beginning disassembly.
Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a spudger to carefully release the tabs on the three ZIF connectors securing the ribbon cables to the motherboard.
Carefully pull the ribbons out with tweezers.
Еще один человек закончил это руководство.
