Nexus 5 Back Cover Replacement
Выберете то, что вам нужно
  1. Nexus 5 Back Cover Replacement, Back Cover: шаг 1, изображение 1 из 3 Nexus 5 Back Cover Replacement, Back Cover: шаг 1, изображение 2 из 3 Nexus 5 Back Cover Replacement, Back Cover: шаг 1, изображение 3 из 3
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
Заключение
43 человек успешно провели ремонт по этому руководству.
Gaetan
Участник с: 12/26/12
9 613 Репутация
Автор 18 руководств
5 Комментарии к руководству
Where do you find backs for the Nexus 5? Thanks!
Mark Brown - Ответить
can you tell me if removing the cover of the nexus 5 GPS stops working well?
daniele neri - Ответить
Back cover LG spare part numbers are:
Black: ACQ86691011
White: ACQ86691012
Red: ACQ86691013
Google them. Done.
nexus555 - Ответить
Thank you very much.
Jesse Wind -
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 20
За последние 30 дней: 63
За всё время: 73,040
