Nexus 5X Rear Panel Replacement
Выберете то, что вам нужно
  1. Nexus 5X Rear Panel Replacement, SIM Card Tray: шаг 1, изображение 1 из 3 Nexus 5X Rear Panel Replacement, SIM Card Tray: шаг 1, изображение 2 из 3 Nexus 5X Rear Panel Replacement, SIM Card Tray: шаг 1, изображение 3 из 3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Rear Panel Replacement, Rear Panel: шаг 2, изображение 1 из 3 Nexus 5X Rear Panel Replacement, Rear Panel: шаг 2, изображение 2 из 3 Nexus 5X Rear Panel Replacement, Rear Panel: шаг 2, изображение 3 из 3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    A guitar pick is a good substitution for the plastic opening tool.
    Sam Sippe - Ответить
    Here’s a photo of the location of the 18 tabs that hold the back cover in place
    Steve - Ответить
    Twisting sideways didn’t do it for me, but sliding along the edge did. However, at first I didn’t realize that the pick was between the motherboard and midframe, rather than between midframe and back cover like it was supposed to. This led to breaking off a spring-loaded connector on the motherboard, connecting to an antenna (I guess) in the back cover. So far I haven’t noticed any reception issues, but I can’t say for sure.
    In essence: be careful to get the pick towards the back cover, and not “straight in” under the midframe.
    Hampus - Ответить
  3. Nexus 5X Rear Panel Replacement: шаг 3, изображение 1 из 3 Nexus 5X Rear Panel Replacement: шаг 3, изображение 2 из 3 Nexus 5X Rear Panel Replacement: шаг 3, изображение 3 из 3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Rear Panel Replacement: шаг 4, изображение 1 из 2 Nexus 5X Rear Panel Replacement: шаг 4, изображение 2 из 2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
Заключение
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
204 358 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 299 руководств
Один комментарий
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 22
За всё время: 8,727
