Nexus 7(1st Generation) Battery Replacement
Выберете то, что вам нужно
  1. Nexus 7(1st Generation) Battery Replacement, Taking the rear case off.: шаг 1, изображение 1 из 1
    • Use the opening tools to open the rear case.
    • Be careful when opening rear case because the rear case clips can break.
  2. Nexus 7(1st Generation) Battery Replacement, Taking battery out: шаг 2, изображение 1 из 1
    • Frist take the spudgler tool to move the wires from the mother board.
    • Second use the tool to pry the battery out of the top then do this at the bottom. Be careful when you do this because there is adhesive under the battery.
    • Im sorry I don't have picture of taking the battery out but the first picture in the circled part that is the motherboard.
    • When you put the new battery in you first put the battery in then you move the wires to the motherboard then but the case back on.
    • Turn the tablet on and there you go. Thank you for using my guide and if it was helpful please leave a comment or if something is not correct on my guide leave a comment and I will fix the correction in my guide.
Заключение
To reassemble your device follow step 3.
2 человек успешно провели ремонт по этому руководству.
Skyler Wright
Участник с: 07/07/17
132 Репутация
1 руководство автора
2Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 6
За последние 30 дней: 10
За всё время: 1,106
