Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show you how to replace the side buttons on your Nexus 9. If your buttons are not depressing fully or are jammed, you may need to replace them.
Выберете то, что вам нужно
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Carefully peel up the copper shielding with your fingers.
Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
The antenna board should now lift free of the motherboard.
Remove the three 3 mm T5 Torx screws.
Remove the five 2 mm Phillips #000 screws.
Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
Pull up the ribbon connector with your fingers.
Refer to the rear-facing camera replacement guide to remove the rear-facing camera from the motherboard and transfer it to the new one.
The motherboard remains.
Using your tweezers, gently grasp the clear rubber backing and pull outward. The buttons should come free.
2 участников успешно повторили данное руководство.
