Введение
In this repair guide we will guide you through the steps necessary to remove and replace the battery found within the NikePlus Sportband.
Выберете то, что вам нужно
To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
Flip the body of the device over so that the screen is now on the bottom.
The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
Flip the body of the device back over so that the screen is facing up.
Using the tweezers, gently lift the screen from body of the device.
Remove the four highlighted screws from the motherboard using the Philips screwdriver.
Gently lay the motherboard upside down exposing the underside of the motherboard.
The red and black battery wires may need to be desoldered from the board. Check out the How To Solder and Desolder Connections guide for some helpful tips on this.
Using the flat edge of a spudger separate the battery from the body of the band.
Еще один человек закончил это руководство.
