Nikon Coolpix S210 LCD screen Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix S210 LCD screen Replacement, Battery: шаг 1, изображение 1 из 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 LCD screen Replacement: шаг 2, изображение 1 из 2 Nikon Coolpix S210 LCD screen Replacement: шаг 2, изображение 2 из 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nikon Coolpix S210 LCD screen Replacement, Back Case: шаг 3, изображение 1 из 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 LCD screen Replacement: шаг 4, изображение 1 из 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 LCD screen Replacement: шаг 5, изображение 1 из 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 LCD screen Replacement: шаг 6, изображение 1 из 2 Nikon Coolpix S210 LCD screen Replacement: шаг 6, изображение 2 из 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 LCD screen Replacement, LCD screen: шаг 7, изображение 1 из 3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: шаг 7, изображение 2 из 3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: шаг 7, изображение 3 из 3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 LCD screen Replacement: шаг 8, изображение 1 из 1
    • Gently remove the LCD screen.
Заключение
2 участников успешно повторили данное руководство.
Mallory Arend
Участник с: 01/17/11
444 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 5-17, Amido Winter 2011 Участник Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 членов
Автор 12 руководств
Один комментарий
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 15
За всё время: 3,978
