Введение
Has the lens on your Nikon Coolpix S230 ceased to function properly due to scratches, exposure to water, or other damage? This guide will walk you through all the steps to access and remove the damaged lens assembly so that it can be replaced with a working assembly.
Выберете то, что вам нужно
Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
Remove the two 3-mm screws from the other side of the camera.
Finally, remove the three 4-mm screws from the bottom of the camera.
Insert the plastic opening tool into the seam where the front and back parts of the case meet on the bottom of the camera, and slide it along the bottom. Continue along the next side to separate the back part of the case.
Lift the back off of the case.
Инструмент, используемый на этом этапе:Tweezers$4.99
Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
Using tweezers, lift the black retaining flap holding down the larger orange ribbon cable.
Carefully remove the ribbon cable from the ZIF connector as before.
Lift the button circuit board by gently popping it out of its connector.
Using a Phillips #000 screwdriver, remove the four 4-mm screws from the metal place.
Use tweezers to lift the beige retaining flap for the smaller, orange ribbon cable that attaches the motherboard to the lens.
Use tweezers to gently pull the orange ribbon cable from the ZIF connector.
Remove the solder using a soldering iron by following the instructions in this guide.
Using a Phillips #000 screwdriver, remove the two visible 5-mm screws that attach the lens to the camera.
Remove the third 5-mm screw by carefully lifting the large ribbon cable that is attached to the lens.
